Is it possible, after creating and editing a new dashboard, to change his name?
If yes, how? I was not able to find an option in the UI to do that…
Yes, click the edit icon, in this example the dashboard is named “lys”.
You can probably do it manually by editing the dashboard in the lovelace file under .storage too if you want.
If you want to edit the name on the “whole” dashboard there is an option for that in the GUI (Settings → Dashboard → click the dashboard you want to rename):
You mean, as actually i have a lovelace.dashboard_test inside the .storage, i can rename it as lovelace.dashboard_mobile for example?
Would assume so, probably safer to do it in the GUI though.
