I have a modbus sensor that returns numeric state values, each value representing a specific mode of operation. I would like to translate those numeric values over to a text description of the operating mode. The following code in configuration.yaml returns the modbus numeric values as expected:
modbus:
type: tcp
host: 192.168.1.37
port: 502
platform: modbus
scan_interval: 10
registers:
- name: Outback_Operating_Mode
hub: AXSPort
register: 41517
Then, based on this thread https://community.home-assistant.io/t/wanting-to-map-sensor-number-value-to-words/40663/7 I tried tacking on the " - platform: template" section as seen here.
modbus:
type: tcp
host: 192.168.1.37
port: 502
platform: modbus
scan_interval: 10
registers:
hub: AXSPort
register: 41517
sensors:
outback_operating_mode_text:
friendly_name: "Outback_Operating_Mode_Text"
unit_of_measurement: "State"
entity_id: sensor.outback_operating_mode
value_template: >-
{% set mapper = {
'0' : 'Off',
'1' : 'Searching',
'2' : 'Inverting',
'3' : 'Charging',
'4' : 'Silent',
'5' : 'Float',
'6' : 'EQ',
'7' : 'Charger Off',
'8' : 'Support',
'9' : 'Selling',
'10' : 'Pass Through',
'11' : 'Offsetting' } %}
{% set state = states.sensor.outback_operating_mode.state %}
{{ mapper[state] if state in mapper else 'Unknown' }}
Unfortunately, this configuration fails validation:
Guessing the problem is a fairly basic oversight on my part, but I’m pretty new at this. Any guidance would be appreciated.
Thanks!
123
(Taras)
February 16, 2021, 6:10pm
2
Indent the first sensor’s configuration and include a hyphen.
- platform: modbus
scan_interval: 10
registers:
hub: AXSPort
register: 41517
sensors:
In addition, unless you are running a very old version of Home Assistant, remove the following line from the Template Sensor:
That convention was deprecated several versions ago.
Thanks for the quick reply and for the tips! I implemented those changes, but unfortunately I’m still getting a validation error. My code now look like this:
modbus:
type: tcp
host: 192.168.1.37
port: 502
- platform: modbus
scan_interval: 10
registers:
hub: AXSPort
register: 41517
sensors:
value_template: >-
{% set mapper = {
'0' : 'Off',
'1' : 'Searching',
'2' : 'Inverting',
'3' : 'Charging',
'4' : 'Silent',
'5' : 'Float',
'6' : 'EQ',
'8' : 'Support',
'9' : 'Selling',
And here is the error I’m getting:
finity
February 16, 2021, 7:28pm
4
you need to indent “friendly_name:” under “outback_operating_mode_text:”
sensors:
value_template: >-
{% set mapper = {
'0' : 'Off',
'1' : 'Searching',
'2' : 'Inverting',
'3' : 'Charging',
'4' : 'Silent',
'5' : 'Float',
'6' : 'EQ',
'8' : 'Support',
'9' : 'Selling',
123
(Taras)
February 16, 2021, 7:34pm
5
Deleted because it was redundant. Didn’t see finity’s reply until web page refreshed in my browser.
Fantastic! That worked! Seems I need to find the manual on proper spacing. Thanks again @123 and @finity !
finity
February 16, 2021, 8:29pm
7
Ought to give @123 the solution. He helped you with the majority of it.
He would have fixed the last bit too but I jumped in on it before he did.
123
(Taras)
February 16, 2021, 8:35pm
8
Thanks for that but it’s all good; I should’ve identified the second syntax error in my first post.
