I understood, that all changes in one of the listed items under entity_id will change the value depending on the value_template. I tought it would change from on to off (or the the way round) when I change the input_number.slider1 in a max or minimum using a slider in the gui.
But exactly nothing happens and the state of “wind_alarm_state” is from the begin on ‘off’.
Has anyone any suggestions?
Hi Marius,
thank a lot for showing this.
I am, as you suggest for shure, just at the beginning with this tricky syntax.
I’didnt know about the combination of comands like the “set = …” with other logics in double {{ }} .
That’s cool. Thank you again for your advise! From now on my code will be more tidy at all.
Double thumb up!
Bernd
