Change of password in the device - only way is deletion
Remember several integrations i had to delete completely due to device change. Won’t remember which ones. Believe it’s bosch connect, shelly…
Now running the custom Dahua integration (it’s just a doorbell) and facing the same problem. Just can’t find the setting where to edit the settings for the integration. Remember one integration just said re-add the device and you will be fine which worked. But maybe there is a unified way? Maybe somewhere in the device registry?
