Change of usb port conbee stick
I run HA on my synology in a VM and all of a sudden the USB stick didnt mount anymore in my vm causing all the devices and entities being unavalable.
Put the stick in another USB and that seems stable.
How do i change the path for the zigbee controller in HA to point to the new USB location? I configured it all through the UI and there seems no way to change the config to point to the new path without removing and adding the integration again. If i do that I have to rename all my device and entities afterwards (or is there an easy to keep the names and entity ids)
I cannot directly help with the hardware but… one can save the entities…I did this a year ago or so and sadly I cannot remember exactly how other then to update the .storage file(s?).
You could test it out with a secondary HA install if you really have a lot to reconfigure
