Is there an official method for making a change request for an add-on?
My request is to please add “8080/tcp”: 8080, to the ports in config.json for the mosquitto add-on.
That will allow websockets support to be configured by a user without having to install a local mosquitto add-on.
You can fork this repo, make the changes you’d like to see implemented, and then submit a pull request comparing your fork and the official repo with the appropriate description. The devs are likely to respond soon after you submit the PR.
First time. Hope I did it correctly.
