Change scene's with a button - Automation
I’ve created a helper with x3 scenes as a drop down.
I have an automation that cycles through the scenes with the automation below… I can see it cycles with each button press, however I’m not sure how to have them activate
How do I activate each scene when the button is pressed?
Thanks guys…
alias: Theme Select
description: Press, cycles through the theme
  - platform: state
    entity_id:
      - input_button.theme_button
condition: []
  - service: input_select.select_next
      cycle: true
      entity_id: input_select.cinema_themes_list
mode: queued
variables:
  scene_mapper:
    Warm: scene.cinema_warm
    Ocean: scene.cinema_ocean
    Cyberpunk: scene.cinema_cyberpunk
max: 10
See the automation in this post:
Awesome!.. thanks Tom :pray:
