My sensor sends the following MQTT payload pressure in hPa:
{"pressure":1014.9}
This value is displayed as 1.014,9
in an entities card:
How can I display this value in format 1014.9
? (Remove dot for thousands)
{"pressure":1014.9}
If your locale is currently supported, then make sure your browser locale is correct. Otherwise you just need to wait until the locale is supported.
Comma for thousands and full-stop for decimal point is the English language default.
Thanks for your fast reply. Unfortunately, I tried different browsers with different locals such as English UK and Dutch, but the display format did not change.
I’ll check / open an issue in the front-end tomorrow.
Related frontend issues incorrect number formatting:
It looks like number formatting is inconsistent between cards, even with a fixed configuration.yaml
homeassistant:
unit_system: metric
time_zone: Europe/Amsterdam
Not related to regional setting in web browsers.
