Hi, I wasn’t really able to find a solution after reading about this for my specific setup…
I have an alarm configured.
I basically would like the sensor icon (ajustement alarme) to change color when I enable the input boolean (activer alarme)…
My sensor (the one that needs to change color based on the input boolean)
sensors:
alarm_time:
value_template: '{{ "%0.02d:%0.02d" | format(states("input_number.alarm_clock_hour") | int, states("input_number.alarm_clock_minute") | int) }}'
my input boolean:
alarm_clock_status:
icon: mdi:alarm-check
initial: off
Thanks in advance…
Is it at least possible or only the entity that triggers can change its own icon?
sure,
using custom-ui, you can do this:
input_boolean.*:
templates:
icon_color: >
if (state === 'on') return 'rgb(251, 210, 41)';
return 'rgb(54, 95, 140)';
or:
input_boolean.home_mode_party:
templates:
icon: >
if (state === 'on') return 'mdi:cake-layered';
return 'mdi:hotel';
icon_color: >
or using the state of another entity:
group.personal:
templates:
icon: >
if (entities['sensor.family_home'].state === '0') return 'mdi:account-off';
if (entities['sensor.family_home'].state === '1') return 'mdi:account';
if (entities['sensor.family_home'].state === '2') return 'mdi:account-multiple';
if (entities['sensor.family_home'].state === '3') return 'mdi:account-multiple-check';
return 'mdi:account-group';
for template sensors, the built-in HA options are here: https://www.home-assistant.io/components/sensor.template/#configuration-variables
Specifically for my needs, what would be the advantages of custom UI vs built-in?
I’m trying to avoid too much custom stuff (as much as possible).
And using builtin, I have no idea how to do this honestly… still learning
I need help finishing this up (I think I’m close) but I’m lost in the syntax of this…
I’m try the builtin way (no custom-UI)
Am I close? I’m trying, in customize.yaml to have the sensor “sensor.alarm_clock_time_long” change color when the input boolean “input_boolean.alarm_clock_status” is “on” (and back to original color when it’s off).
sensor.alarm_clock_time_long:
hidden: true
icon: mdi:alarm
friendly_name: 'Alarme'
templates:
rgb_color: "if (states.input_boolean.alarm_clock_status === 'on') return [253, 216, 53]; else return [68, 115, 158];"
Getting this would help me understand better other things as well.
Thanks again in advance!!!
reading the topic title, that would be it. Cant do that with regular sensor template.
btw Custom-ui is one of the most accepted custom cards, and brings heaps of frontend improvements I could do without. Easy install, very light weight.
sfnetwork:
hidden: true
icon: mdi:alarm
friendly_name: ‘Alarme’
templates:
rgb_color: “if (states.input_boolean.alarm_clock_status === ‘on’) return [253, 216, 53]; else return [68, 115, 158];”
try:
#hidden: true
icon: mdi:alarm
templates:
icon_color: >
if (entities['input_boolean.alarm_clock_status'] === 'on') return 'rgb(253, 216, 5)';
return 'rgb(68, 115, 158)';
not sure why you want to customize it if you’re hiding it…
Mariusthvdb:
templates: icon_color: > if (entities[‘input_boolean.alarm_clock_status’] === ‘on’) return ‘rgb(253, 216, 5)’; return ‘rgb(68, 115, 158)’;
The hidden part was a mistake, I changed it to “false”.
I tried this as you suggested in customize.yaml but after reboot, it still doesn’t work…
hidden: false
icon: mdi:alarm
friendly_name: Alarme
templates:
icon_color: >
I confirmed the state of the input boolean is really switching to “on”.
Man I feel, it’s close…
BTW, is this using custom-ui or builtin?
sfnetwork:
this is custom-ui. as said, icon_color is not an option for built-in template sensors. You need to install custom-ui first for this to be used in your setup . See the link I provided earlier to do so.
ok and the template lines you shared, need to be in customize or customizer? Sorry, I just want to make sure I get the differences…
did you read the doc’s I posted? It’s all there…
I use a config/customize folder where all my customizations are stored.And referenced in configuration.yaml by:
homeassistant:
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
unit_system: metric
time_zone: !secret time_zone
customize: !include_dir_merge_named customize
customize_glob: !include customize_glob.yaml
packages: !include_dir_named packages
whitelist_external_dirs: /config
Ultimately, it simply needs to be under
homeassistant:
customize:
#hidden: true
icon: mdi:alarm
templates:
icon_color: >
depending on your splitting up the configuration, his needs to be adapted accordingly.
I did and I thought I got it but it doesn’t work so I question myself…
in my configuration.yaml:
customize: !include customize.yaml
# Enable the auth component
# auth:
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
extra_html_url:
- /local/custom_ui/state-card-custom-ui.html
extra_html_url_es5:
- /local/custom_ui/state-card-custom-ui-es5.html
and
customizer: !include customizer.yaml
in my customize.yaml
#hidden: true
icon: mdi:alarm
templates:
icon_color: >
in my customizer.yaml:
custom_ui: local
And all files are placed in correct locations based on the docs…
Am I missing something?
take out the customizer part? I don’t use that option for custom_ui.
bw, I use a dir_merge_named customize and folder /config/customize
in that folder I have dedicated files .yaml for all of my customizations
