EchoWisky
(Erik Wachters)
September 22, 2020, 10:12am
1
I have the following sensors defined but I have no clue how to change it to the v115 without entity_id.
sensors:
erik_last_location_update:
friendly_name: "laatste update."
entity_id:
- sensor.erik_latitude
- sensor.erik_longitude
value_template: >
{{now().strftime('%d-%h-%y - %H:%M:%S') }}
Can you point me in the right direction?
Thank you
Erik
finity
September 22, 2020, 10:27am
2
I haven’t tried it but this should work I think:
sensors:
value_template: >
{% set lat = states('sensor.erik_latitude') %}
{% set lon = states('sensor.erik_longitude') %}
Kabala
(Cata)
September 22, 2020, 10:47am
4
I have the same problem.
BinarySensorDevice is deprecated, modify LuxtronikBinarySensor to extend BinarySensorEntity
binary_sensor:
sensors:
heating:
value_template: "{{ is_state('luxtronik.id_web_wp_bz_akt', 'heating') }}"
friendly_name: "Heizen"
sensors:
hot_water:
value_template: "{{ is_state('luxtronik.id_web_wp_bz_akt', 'hot water') }}"
friendly_name: "Warmwasser"
sensors:
solar_pumpe:
value_template: "{{ is_state('luxtronik.id_web_slpout', 'on') }}"
friendly_name: "Solarladepumpe"
sensors:
evu_sperre:
value_template: "{{ is_state('luxtronik.id_web_wp_bz_akt', 'evu') }}"
friendly_name: "EVU"
sensors:
verdichter:
value_template: "{{ is_state('luxtronik.id_web_vd1out', 'on') }}"
friendly_name: "Verdichter"
Tediore
September 22, 2020, 11:41am
5
That’s not the same issue, that’s an issue with that custom integration (luxtronik). Check if there’s an update for it.
andie_will5
(Andie Will5)
September 22, 2020, 11:47am
6
Hi i’m having an issue trying to figure out how to change this automation, but keep coming up to a dead end, and i have several automation like this as well that need changing, any help would be much appreciated
## Automation Lights
- alias: Motion Sensor Lights On
platform: state
entity_id: binary_sensor.presence_5
to: 'on'
condition:
condition: numeric_state
entity_id: sensor.lightlevel_2
below: 20
service: homeassistant.turn_on
entity_id: light.hallway_light
transition: 2
- alias: Motion Sensor Lights Off
- platform: state
to: 'off'
for:
minutes: 3
- service: homeassistant.turn_off
transition: 5
poudenes
(Poudenes)
September 22, 2020, 11:58am
7
I have this template
# SENSOR TEMPLATE
# https://www.home-assistant.io/integrations/template/
platform: template
sensors:
github_milight_hub_version:
entity_id: sensor.date
value_template: "{{ (states.sensor.github_milight_hub.attributes['latest_release_tag']) }}"
github_espeasy_version:
value_template: "{{ (states.sensor.github_espeasy.attributes['latest_release_tag']) }}"
The entity is used when its 00:00:00 to new day then sensor will be updated.
If I remove it, how can I let update this sensor then?
finity
September 22, 2020, 12:52pm
8
by using a similar format to what I wrote above:
platform: template
sensors:
value_template: >
{% set update = states('sensor.date') %}
But be aware that it should also update when the sensor.github_espeasy changes too.
petro
(Petro)
September 22, 2020, 12:53pm
9
That doesn’t need to change. The errors in your log will point to a section, like ‘binary_sensor’, or ‘sensor’. entity_id is not deprecated in automations.
