I’m using a few Fibaro Dimmer 2 dimmers, i’m trying to change some settings, such as what happens when someone pushes the s1 of s2 button (the buttons on the wall).
Link to dimmer:
Can’t find it anywhere in HA.
Thanks!
Link to dimmer:
Thanks!
if it’s in the node config then you go to the menu on the left and go to ‘configuration’, then to ‘z-wave’, then select the node in the drop-down list.
Thanks, found it
