Change slider based on template value
I have a slider defined in helpers called tesla_current_slider, and want to change it in an automation action based on the value of a template.
However when trying this:
In configuration.yaml:
   sensors:
     test8:
       value_template: "{{ 8 | float }}"
In an automation action:
service: input_number.set_value
  value: {{ test8 | float }}
  entity_id: input_number.tesla_current_slider
expected float for dictionary value @ data[‘value’]. Got None
or like this:
  value: "{{ test8 | float }}"
Error rendering data template: UndefinedError: ‘test8’ is undefined
I’ve tried a lot of things, but none seem to work. Is it possible to use it like this?
You don’t get the state of your template sensor with {{ test8 }}.
Try {{ states('sensor.test8') | float }}
So simple, but didn’ t figure out how to do it.
Thank you so much!
