Hi!
I need to add multiple conditions to one automation. If “device_tracker.Mua_iphone” and “device_tracker.Mark_iphone” is “away” (everybody are away) I want to play the sound fanfar.mp3. If Mua_iphone are “home” i want to play MUA.mp3. If device_tracker.Mark_iphone are “home” I want to play MARK.mp3.
This is my automation on the front door today:
- id: '1570641644419'
alias: Automation_Front_Door
- entity_id: binary_sensor.sensor_front_door
platform: state
to: 'on'
condition: []
- service: media_player.play_media
data_template:
entity_id: media_player.baa
media_content_id: http://soundking.com/sounds/fanfar.mp3
media_content_type: audio/mp3
- service: media_player.volume_set
data_template:
volume_level: 0.5
First, please format your YAML code properly. We can’t read it well as it is.
So, if I understand correctly, when the front door opens, you want to play a particular audio file depending on who is home. Is that correct? If so, what you want to do is to use a template for media_content_id
. If you can format your code correctly, I can suggest what you might want.
Yes, much. Thanks!
Do you think this might do what you want?
platform: state
to: 'on'
condition: []
data_template:
media_content_id: >
{% if is_state('device_tracker.Mua_iphone', 'home') %}
http://soundking.com/sounds/MUA.mp3
{% elif is_state('device_tracker.Mark_iphone', 'home') %}
http://soundking.com/sounds/MARK.mp3
{% else %}
{% endif %}
data_template:
volume_level: 0.5
I suspect that this might not actually be what you want, but since you didn’t answer my question…
It’s works perfect! Thank you!
