I have a switch in a glance card and the state shows as on or off. I would like to change the state label to open closed. I have tried sensor template, but that converts the switch to a sensor. What should I use. I do have card mod installed if that helps?
I dont know if this works out for you, but I do this using the custom button card. Its highly customizable.
This is my card config
entity: switch.shemin_bedroom_light
tap_action:
action: none
show_name: true
show_icon: true
show_state: false
show_label: true
label: |
if (states['switch.shemin_bedroom_light'].state === "on")
return "Open";
else if (states['switch.shemin_bedroom_light'].state === "off")
return "Close";
styles:
name:
- left: 28%
- top: 5%
- position: absolute
card:
- height: 130px
label:
- left: 43%
- top: 79%
type: 'custom:button-card'
This is how it looks in my UI
Switch are either on or off. That’s what they do, switch things on or off. How can a light be “open”?
Binary sensors can have device classes applied to represent more than on or off in the frontend.
Thank you both for your help. My problem is I am using Konnect to unlock a door. So I must use a switch, I can’t seem to make a binary sensor in Konnect swicth. Do I have any other options. I was hoping not to need custom cards, as I prefer the glance card. The label code doesn’t seem to work in the glance card for me.
Convert your switch into a lock:
Template Lock is good but will give you “locked” and “unlocked” states. If you want open/closed maybe you want a Template Cover:
Did you ever get this figured out? I’m having the same issue right now
It’s a long time ago this was answered.
Tom, may I ask the same question but now later an maybe more doable?
I am looking into a way to change a switch from on/off to left/right.
I know a switch can only be on/off but I need a switch to present itself as left/right in my interface (or logic).
Is there a way to change the state name of a switch? Or create a template switch?
A template sensor wouldn’t work for your scenario?
sensors:
test:
friendly_name: 'Test'
unique_id: test
value_template: >-
{%- if is_state('switch.xxx', 'on') %}
left
{% else %}
right
{%- endif %}
I think that is only partially… it is a sensor then, not a switch
It depends on the application you are using it in. It’s still an entity that changes based on a state.
More information would help folks understand your end goal.
