When I placed my Android phone on charge I want to be able to save that state and use it for automation. I can use IFTT then notify Home Assistant when my phone goes onto charge… but what does the setup look like from Home Assistant’s point of view?
I don’t use the internet for my automations, so I use Llama to detect the connection of the phone and run an http shortcut but the net result should be the same - I use the api to set the state of an input_select defined in the configuration like
input_select:
in_bed:
options:
- InBed
- Up
