I use the thermostat card for my heating.
Visually, I do not quite like it.
Especially the thickness of the line in the circle (I hope you know what I mean) is too thin for me.
I am talking about the 3/4 circle to control the temperature and the point on this line.
I would like to set the thickness of the line to 10 and the dot to 24, but I don’t know how.
I have identified the corresponding CSS elements by chrome and web-inspector.
CIRCLE:
Then I installed “lovelace-card-mod” and tried to access the CSS elements with it.
Unfortunately without success. The mod works, I can see that by the fact that I can change e.g. the font, but unfortunately not the stroke-width of the circle and the dot.
Does anyone have an idea how I can change these two elements?
The new design is only visible after you click the “three dots” on the climate card. Until then, you still see the original (less attractive) layout that is the subject of this thread. But I believe they are looking at changing this so the new improved design will get applied to the default/initial view as well? I certainly would love to see that!
