Hi, I have a problem changing my entity´s icon. As you see in the picture is the green one correct so I want to change the flashes to a switch like the green one. So it´s not the bulb it’s only the flashes. Thanks in advance.
Cheers
Cheers
if you see the 2 lightning bolts, that means your switch doesn’t produce a state. Meaning home assistant doesn’t know if the switch is on or off. Home assistant will only display the toggling switch if the switch itself lets HA know that it’s on or off.
Aha … I need to change the 433MHz devices. Thanks for your quick answer
You can add assumed_state: True via customizations but it will get out of sync with the hardware on restarts.
I’m digging out this thread for a side question…
Is it possible to change the bolt icons ?
I have a very specific usecase and would like to change those bolts with something else (arrows up and down in my case).
I don’t believe you can.
