i am trying to setup a simple automation, once i press zigbee button i want to change the state of the other switch.
I went thru the forum, and found thread How to manually set state/value of sensor? - #77 by petro
where they use custom service/script > service: python_script.set_state
and then some other custom made code which utilizes the python script.
data_template:
entity_id: binary_sensor.wallpanel_entrance_sensor_motion
state: >
{% if trigger.to_state.state == 'off' %}
Unavailable
{% else %}
{% set sensor_state = states('binary_sensor.wallpanel_entrance_sensor_motion') %}
{{ 'Clear' if sensor_state == 'Unavailable' else sensor_state }}
{% endif %}
I was wondering if there is some simpler option to do that these days?
All i want to do is as mentioned, once i press the zigbee button, it shoud change the state of the switch ie if the switch status is on → off , or off->on.
Thank you
