Change temperature of air-con at specific time Only if the Air-con is on
I’m trying to figure how to change the temperature to 25 degrees at 7am Only if the Air-con is currently on. If it’s off then remain off.
I have Daikin air-condition. I try to set it but when i ran the automation it will turn on the Air-con automatically when it’s off. I needed it to remain off.
Thank you
Post the automation you created (as formatted YAML).
All it needs is a State Condition that confirms the air-conditioner is currently on.
My Automation is
Trigger
State
Entity : Bedroom air con
Mode : Fixed time
At time: 12:00 Pm
Condition
State
Attribuit : Current action
State: cooling ( please not there is no ON condition to choose from. Only Off , idle, heating, cooling, Drying, Fan are available )
Actions
Service: Set Temperature
Target: Bedroom air con
Temperature: 26
I don’t know what you posted but it’s not a valid automation.
I suggest you use Home Assistant’s Automation Editor to create the automation.
