Hello guys! I need some help to define a configuration to change the color of the card background based on a range of values. For example:
- The temperature is higher than 25 celsius degrees: red
- The temperature range is between 15 and 25 degrees: orange
- The temperature is lower than 15 degrees: blue
The idea is to extend the same setup to humidity values as well, but based on percentages here:
- the humidity is below 40%: red
- the humidity range is between 41 and 70%: orange
- the humidity is higher than 70%: green
I am supposed to be simple do that using button-card for different conditions based on states. But what about values? Could anyone give me some assistance, pls?
