Change the look of switch
can i change the mamad light to look like the gatewey light?
this is my config:
switch:
  • platform: broadlink
    host: 192.168.1.61
    mac: ‘xxxxxxx’
    timeout: 15
    switches:
    Will work on most sony TVs:
    tv_sony:
    friendly_name: “Sony Tv Power”
    command_on: ‘JgA0AVESFRIoEykTKBMVEikSFRMoExUSFhIVEhUAAztREhYSKRMpEikSFRIpExQTKRIVExUSFRMVAAM7UBIVEygTKRIpEhUTKRIVEioSFBMVExUSFQADPFATFRIoEykSKRMUEygTFRMoExQTFRMUExUAAzxPExUTKBMoEygTFRMoExQTKBMVExQTFRQUAAM8UBIVEygTKBMoExUTKBMVEikTFBMVEhUTFQADPE8TFBMpEikTKBMUEykSFRMoExUSFhMUExUAAzpRExUSKRMoEygTFRIpExQTKBMVExQTFRMUAAM9TxIVEygTKBMpEhUTKBMVEygUFBMVEhUTFAADPFATFBMpEikTKBMUEygTFRMoExUSFRMUExUAAzxPExUTKBMoEygTFRMoExUTKBMVExQTFRMUAA0FAAAAAA==’
    command_off: ‘JgA0AVATKBMoEykSKRMUEygTFRMoExQTFRMUExUAAyhPEykSKRMoEykTFBMpEhUTKBMVEhUTFRIVAAMoUBMoEygTKBMoExUTKBMUEykSFRMVEhUTFAADKU8TKBMoEykTKRIVEygTFRMoExQTFRMUExUAAydQEykSKRMoEygTFRIpExQTKBMVExQTFRMUAAMpTxMoFCgTKBMoExUTKBMUEykSFRMUExUTFAADKFATKBMoEykSKRMUEygTFRMoExQTFRMUExUAAyhQEykSKRMoEygTFBMpEhUTKBMVExQTFRIVAAMpTxMoEygTKBMoExUTKBMVEikTFBMVEhUUFAADKFATKBMpEikSKRIVEykSFRMoExQTFRMVEhUAAyhQEikSKRMoEygTFRIpEhUTKRIVExYSFRIVAA0FAAAAAA==’
    mamad_light:
    friendly_name: “mamad light”
    command_off: ‘shwyABcRGCEHERghBxAYIQchBxAYIQcRFxAYIQchBhEXERcRGBEYEBgQGBAYEBgiBiIGEBjIAAAAAAAA’
    command_on: ‘sigyABkPGh8JDhofCQ4aHwkfCQ4aHwkPGg4aHwkfCQ4aDhoOGg8aDxoOGg4aHwkPGQ8ZDxrGAAAAAAAA’
Check here for assumed_state: https://home-assistant.io/docs/configuration/customizing-devices/
In customize you can change the mdi:icon to a light bulb.
  customize:
    switch.tv_sony:
      icon: mdi:power
Will give you IMO, a neat looking power button also image
    switch.mamad_light:
      icon: mdi:lightbulb
Will give you image
See https://materialdesignicons.com/ for icon options.
Further from the icon change you also can change from switch toggle to look like input_boolean on right hand side picture by using assumed_state: false in customize:
  customize:
    switch.tv_sony:
      friendly_name: Sony TV
      icon: mdi:lightbulb
thx its working
Can I also change the proximity. home to be a budget and to show up like sensor on the top view?
if it is under sensor platform, normally HA will show as badge like sun.sun
Hi !
Might it be possible to change also actual switch outlook, i dont want that lightning outlook, but the default one…
After some digging (on this forum), found this that does the trick :
homeassistant:
customize_domain:
  light:
