Good afternoon everybody.
I have some entities that I can’t change the name in the traditional way … What is the best way for me to do it?
Hi. what is the error message that you are seeing when to try to rename the devices in the traditional way? How are these entities setup? If you have manually setup these entities then you can change the names in the configuration.yaml.
You can always change the friendly name in the UI, using Configuration -> Customizations
thank you so much. I wasn’t getting it because I didn’t have the “homeassistant: customize:! include customize.yaml” ths
