I have a sensor with an attribute ‘departure_time: 14:00’ but the departure time is in the wrong timezone, it should be 12:00 instead of 14:00. So I created a template sensor and I would like to change the output to 12:00 but I can’t figure it out how to…
{{ state_attr('switch.volkswagen_tiguan_departure_schedule_3', 'departure_time') }}
Output of the sensor at the moment: 14:00
and I want it to be 12:00
Can anyone help me with this template sensor? Thanks in advance.
finity
August 17, 2022, 9:00pm
2
{{ (as_timestamp(strptime(state_attr('switch.volkswagen_tiguan_departure_schedule_3', 'departure_time'), '%H:%M')) - 7200 ) | timestamp_custom('%H:%M') }}
Thank you so much! Spend some hours to figure it out but it was beyond my ability
(Taras)
August 17, 2022, 10:13pm
4
Is it always a two hour difference or will it change depending on whether Daylight Saving Time is in effect or not?
I think it will always be a two hour difference, the app of Volkswagen shows the correct time, the sensor is just two hours off.
123
(Taras)
August 18, 2022, 12:25pm
6
Does the two hour difference correspond to the offset of your local timezone?
