Change the value of a sensor ["xx.xxx"]
Temperatura Caldaia (Server Blynk)
gives me this result [“70.688”]
I have to convert it to
70.7
If you have jq available locally, you could try adding | jq -r '.[0]' to the command line.
Try this:
    value_template: "{{ value[0] }}"
no.
i try
value_template: "{{ value | replace (‘[’, ‘’)| replace (‘]’,‘’)| round(1) }}"
result ----“71.250”
When you said this:
I assumed it received a list (because that’s how a list would appear) and so value[0] would return the first item in the list (which would be 70.688).
However, you reported that it didn’t work which means it’s not a list but a string (and it simply has the appearance of a list).
In that case, the simplest way to extract the value is to slice off the parts you don’t want which are the first two and last two characters.
  value_template: "{{ value[2:-2] | round(1) }}"
The technique used is python’s native string-slicing capability.
Here’s a screenshot of the Template Editor demonstrating that the technique works:
Screenshot from 2021-04-06 18-14-37
Work, Thanks
