I have a home assitant setup with 3 z wave honeywell thermostats. I am new to home assistant, but familiar with coding in similar languages as the scripts I have seen.
I am really struggling with what I would assume would be simple. How do I setup a simple automation to change the thermostat settings based on time of day?
Here is where I am confused. , where do the type’s and preset info stuff come from? See below, just not sure where these entities are defined, of course the only things that automatically pop up are change from heat to cool or something like that, no option that I see that changes setpoint temp. Any ideas?
I found this on this forum. Simple Thermostat Scheduler. It’s a python script that I call from an HA automation, every 10 minutes. I heavily modified it to do heating and cooling as well as temporary holds but it works perfectly fine as is for a basic scheduler.
What you want to do is go into the developer section of HA and go to the services tab. Check under climate. and maybe Honeywell and you should see all available ‘call’ commands. When you choose one it will even give you an example below.
Anyone else have any other ideas? The faceplate on lovelace ui changes temperature, why can I not write the code to do the same. The thermostat is a honeywell t6
