Hi All,
Happy 2021!
IS there a way to change the thunder icons for lights:
The light bulb is changeable in customize part. But the thunder part I can’t change.
Cheers,
Hi All,
Happy 2021!
Cheers,
Is that a light entity? What card is this? Is it the modal pop-up on the entity? You need to give more details. Show your relevant config(s) and explain what you’ve done and tried.
entities:
- entity: binary_sensor.zwave2mqtt_nodeid_108_contact
name: Motion Diningroom
- entity: light.dressoir_all
toggle: true
type: 'custom:slider-entity-row'
- entity: light.dressoir_1
toggle: true
- entity: light.dressoir_2
toggle: true
- entity: light.dressoir_3
toggle: true
show_header_toggle: false
type: entities
Just basic from HA itself
usually this is displayed on switches. not lights. you can get the toggle to appear using
homeassistant:
customize_glob:
light.dressoir*: # <---- replace this with you lights, but only if this is needed on all dressoir lights
assumed_state: false
still, seems odd this would be necessary for lights, havent seen that before. Are they special kind of lights?
Where did the lights come from? What integration? Post your configuration for the integration. Also, go to developer tools -> states page and take a screenshot of the light.
You’re assuming he uses customui…
The Light is not in customize or global
- name: "Dressoir 1"
command_topic: "Milight_Hub/0xAAAF/rgb_cct/1"
state_topic: "Milight_Hub/states/0xAAAF/rgb_cct/1"
<<: &MILIGHT_PARAMS
platform: mqtt
schema: json
color_temp: true
rgb: true
brightness: true
effect: true
qos: 1
optimistic: true
retain: false
availability_topic: "Milight_Hub/client_status"
payload_available: "connected"
payload_not_available: "disconnected"
effect_list:
- "night_mode"
- "white_mode"
- "0"
- "1"
- "2"
- "3"
- "4"
- "5"
- "6"
- "7"
- "8"
- name: "Dressoir 2"
command_topic: "Milight_Hub/0xAAAF/rgb_cct/2"
state_topic: "Milight_Hub/states/0xAAAF/rgb_cct/2"
<<: *MILIGHT_PARAMS
- name: "Dressoir 3"
command_topic: "Milight_Hub/0xAAAF/rgb_cct/3"
state_topic: "Milight_Hub/states/0xAAAF/rgb_cct/3"
<<: *MILIGHT_PARAMS
- name: "Dressoir All"
command_topic: "Milight_Hub/0xAAAF/rgb_cct/0"
state_topic: "Milight_Hub/states/0xAAAF/rgb_cct/0"
<<: *MILIGHT_PARAMS
You don’t have a state_value_template for any of those lights so the system doesn’t know if the light is on or off. Add a state_value_template and it will switch from the lightning bolts to a toggle.
HA is know when light is going on.
When I turn it on in the milight_hub interface I see the light goes on in HA as well.
So that is working.
You mean this line then?
state_value_template: "{{ value_json.state }}"
is documented in the core docs, don’t need custom_ui for that:
must admit Im not sure customize_glob is too, but it certainly is for recorder integration, so it might be for customize…
if not, one can customize per entity in core, without custom_ui.
Yes, state_value_template. But the template needs to extract the correct info out of your state_topic to properly handle the state.
Also, you’d probably want an effect_value_template, which does something similar.
Yes, I know that. But you posted code for custom_ui and globbing, which is not in core. To clarify to you: Globbing comes from customui.
as I already supposed myself. Even worse, it is only documented for switches, so OP might not be able to use any of my suggestions…
but, given the fact these are mqtt lights, and your suggestion for a value_template, he should be good to go.
This is the MQTT output:
"state": "OFF",
"status": "OFF",
"brightness": 255,
"level": 100,
"kelvin": 51,
"color_temp": 264,
"bulb_mode": "white",
"color": {
"r": 255,
"g": 255,
"b": 255
"effect": "white_mode"
That I guess this must be correct to add if I want add all the options:
command_off_template: '{"state": "OFF"}'
command_on_template: '{"state": "ON"}'
state_template: '{{ value_json.state }}'
effect_template: '{{ value_json.effect }}'
color_temp_template: '{{ value_json. color_temp }}'
brightness_template: '{{ value_json. brightness }}'
red_template : '{{ value_json.color[0] }}'
green_template : '{{ value_json.color[1] }}'
blue_template: '{{ value_json.color[2] }}'
I would guess so. you can easily add it to your anchor, so give it a whirl.
Tried already. Checker gives a error and VSC say on all lines its not allowed… haha
in a JSON Schema there are no:
command_off_template: ‘{“state”: “OFF”}’
command_on_template: ‘{“state”: “ON”}’
state_template: ‘{{ value_json.state }}’
effect_template: ‘{{ value_json.effect }}’
color_temp_template: ‘{{ value_json. color_temp }}’
brightness_template: ‘{{ value_json. brightness }}’
red_template : ‘{{ value_json.color[0] }}’
green_template : ‘{{ value_json.color[1] }}’
blue_template: ‘{{ value_json.color[2] }}’
So this won’t work.
Change this card like this. Tap on the bulb turn on/off, long press give me color_picker.
Behind the brightness line I see the percentage of brightness.
entities:
toggle: false
tap_action:
action: toggle
hold_action:
action: more-info
toggle: false
tap_action:
action: toggle
hold_action:
action: more-info
toggle: false
tap_action:
action: toggle
hold_action:
action: more-info
toggle: false
tap_action:
action: toggle
hold_action:
action: more-info
type: entities
Rubbish
TIL, wasn’t always there though
