I have a switch to turn my TV on or off (via a Harmony Hub), but it doesn’t always show the correct on/off state.
Is it possible to change it from a toggle switch to the other type of switch with 2 separate lightning bolts? I’ve searched for quite a while and only found a way to do the opposite (change a switch with lightning bolts to a toggle switch, with ‘assumed_state: false’ )
Problem I have is, if I make it false and then turn it on, it goes back to off – I even tried using a script as the assumed_state sending back a true or false if it’s actually on and that just gets stuck in an off state and then I can’t turn it on at all.
I was using the switch.command_line which doesn’t support the assumed_state … rather the command_state but I couldn’t get it to work without adding the (cough) optional settings for value_template. Now it works.
