I have some sensors with impractical state.
For example some Sensors of the ViCare implementation. There is a binary sensor which switches between “detected” and “normal”.
But “on” and “off” would be way more useful.
this depends on the Device_class of the binary sensor.
there are different solutions:
The author of the Integration could change the device class of the sensor itself, to acheive this
or you could create a template sensor - which get the state of the ViCare Sensor, but is using its own device class.
here’s an example - I’ve created a default binary_sensor template which gets the status from the “Betriebsstundenzähler” - another binary_sensor, but with a different device_class…
To be precise, the actual state of a binary sensor will always be on or off.
Depending on the device_class of the sensor, the frontend will display on/off as, e.g., “detected” and “normal”
