Change type of Zigbee shutter
I’m using a Mod on SIN-4-RS-20 relay to controly external shutters. They’re straight up-and-down shutters, but Home Assistant decided some time ago that they’re actually blinds that can also tilt.
How do I override that value so the device shows up as just “up and down” without creating a whole second template shutter in my config?
I tried using setting cluster attributes, but I think I did that wrong somehow - can someone explain what the difference between the value and the manufacturer code override is, and how to properly set them?
Edit: I’m using ZHA with a ConBee 2
It would help if you told what Zigbee stack you are using. ZHA or Zigbee2MQTT.
I’m using ZHA, with a ConBee 2, in case the coordinator matters
you can try to change the device type, see Zigbee - MODIFYING THE DEVICE TYPE
Changing the device type isn’t granular enough. Currently, it’s reporting as a WindowCoveringType.Tilt_blind_tilt_and_lift, but I need something like WindowCoveringType.Shutter.
