Hi there , can we change unit mbit/s to mbps ( Download/Upload ) of Speedtest ? Thank you so much
No because that would mess up my long term monitoring in InfluxDB.
InfluxDB data organisation is based on unit and it has a year or so of Mbit/s already.
Also, moving to Feature Requests.
Thank you sir ^^
Sorry, the smiley face means I was joking.
I can quite easily add a second OR query for another unit in Grafana that uses the IfluxDB data.
From a quick Google search Mbit/s or Mb/s are the preferred units though Mbps is often used. There’s probably an RFC about it somewhere but I cant find it.
Any reason you want it as Mbps instead of Mbit/s
You could make a template sensor that just divides the number by 8 and changes the unit of measurement.
I dont think it was a bit vs byte thing. More Mbit/s vs Mb/s as the unit. I could be wrong.
If thats the case, the template sensor would be even simpler
Customize would be even simpler.
@justintrann You can change the unit easily using this, if all you want to do is change /
to p
rather than changing bits per second to bytes per second.
