Change update interval for entity
I have got sensor Tuya S-JP1 (Temp, Humadity, CO2, VOC).
Integrated with my home assistat by tuya local. It’s works.
But i have got value CO2 peak randomly in time. Temp and humadity is stable value.
I don’t know why!
Bu i have idea change interval update for sensor. I try with parametr scan_interval - dosn’t work
My code in configuration.yaml
    scan_interval: 90
    sensors:
      humadity2:
        friendly_name: "Humadity"
        device_class: humidity
        value_template: >
          {{ states('sensor.humadity')| multiply(0.1) }}
    scan_interval: 90
    sensors:
      temp2:
        friendly_name: "Temp"
        device_class: temperature
        value_template: >
          {{ states('sensor.temp')| multiply(0.1) }}
    sensors:
      temp2:
        friendly_name: "Co2"
        value_template: >
          {{ states('sensor.co2') }}
Screenshot 2021-10-14 at 11-49-09 Test - Home Assistant
You have twice the same temp2 sensor name. Not sure what’s happening in this case.
Also, device_class should be carbon_dioxide
I have corrected but the values for co2 are still jumping
