Change Update Interval of Tile Card?
Using a standard Tile card and a Trigger sensor, we get a card that updates the time since the trigger was tripped, first every second, then every minute, then hour, etc.
Trigger:
  # Test Contact Sensor Last Opened
  - trigger:
      - platform: state
        entity_id:
          - binary_sensor.test_contact_sensor_contact
        to:
          - "on"
      - name: "Test_Contact_Sensor_Last_Open"
        device_class: timestamp
        state: "{{ now() }}"
Yaml Card:
           - type: tile
             entity: sensor.test_contact_sensor_last_open
             icon: mdi:exit-run
             name: Test Contact Sensor
             card_mod:
               style: |
                 ha-state-icon {
                   {% if is_state('binary_sensor.test_contact_sensor_contact','off') %}
                     color: green;
                   {% elif is_state('binary_sensor.test_contact_sensor_contact','on') %}
                     color: red;
                   {% else %}
                     color: yellow;
                   {% endif %}
Dashboard display:
I wanted to add more data to the Tile card, so used a sensor template with attribute_templates to roll all the data up into a single sensor:
Sensor Template:
    sensors:
      my_test_contact:
        friendly_name: "My Test Contact"
        value_template: "{{ states('sensor.test_contact_sensor_last_open') }}"
        attribute_templates:
          battery: "{{ states('sensor.test_contact_sensor_battery')+'%' }}"
          open: "{{ states('binary_sensor.test_contact_sensor_contact') }}"
          link_quality: "{{ states('sensor.test_contact_sensor_linkquality')+'i' }}"
          last_open: >-
             {% with mytime = (as_timestamp(now()) - as_timestamp(states('sensor.test_contact_sensor_last_open'))) | int  %}
               {% if (mytime // 2592000) > 0 %}
                 {{ '{} mth ago '.format(((mytime / 2592000) | float) | round(1)) }}
               {% elif (mytime // 604800) > 0 %}
                 {{ '{} wks ago'.format(((mytime / 604800) | float) | round(1)) }}
               {% elif (mytime // 86400) > 0 %}
                 {{ '{} dys ago'.format(((mytime / 86400) | float) | round(1)) }}
               {% elif (mytime // 3600) > 0 %}
                 {{ '{} hrs ago'.format(((mytime / 3600) | float) | round(1)) }}
               {% elif (mytime // 60) > 0 %}
                 {{ '{} min ago'.format(((mytime / 60) | float) | round(1)) }}
               {% elif (mytime // 1) >= 0 %}
                 {{ '{} sec ago'.format(mytime // 1) }}
               {% else %}
                 {{ 'Unknown' }}
               {% endif %}
             {% endwith %}
And used the Tile card with state_content for the additional data (thanks @reste_narquois) :
          - type: tile
            entity: sensor.my_test_contact
            icon: mdi:exit-run
            state_content:
              - last_open
              - battery
              - link_quality
            card_mod:
              style: |
                ha-state-icon {
                  {% if is_state_attr('sensor.my_test_contact', 'open','off') %}
                    color: green;
                  {% elif is_state_attr('sensor.my_test_contact', 'open','on') %}
                    color: red;
                  {% else %}
                    color: yellow;
                  {% endif %}
This breaks the auto-update feature of the standard Tile card with ‘time since triggered’ reporting, so I had to roll my own output in the template sensor (above).
The problem now is that the new Tile card (on right) only updates every minute, instead of the default of evey second for the first minute, every minute for the first hour, every hour for the first day, etc…(you get the idea).
A while this isn’t an issue if its been hours since the trigger was tripped, its annoying for the first hour :upside_down_face:
Any ideas on how the change the update interval of the Tile Card so it better matching the default ‘since last tripped’ configuration?
Even having it update every 10 seconds would be nice.
Thanks!
