What is the proper way to specify sidebar configuration and default theme that will persist when logging out and loggin back in? Or is that not possible?
Unfortunately this is saved in your browser. So if you have the browser set to clear your browser history when it shuts down then you lose the setting.
@erikor - is there a more elegant solution for this problem that you found (another way to default to a certain theme and sidebar settings) or did you just stop clearing the browser cache?
Also how do you hide the sidebar with an automation?
I have never logged out explicitly from HA - so my settings (theme, sidebar) were persistent.
Surely when I cleared a browser’s cache - I had to login again, set a theme, a sidebar etc.
I thought that I have to re-login & re-set settings since cookies are deleted.
Now I realized that if I logout - then after re-login all my settings are “purged”.
Seems that these “local settings” are “purged” after logout - even when I do not clear a cache manually and I do not know anything about settings for “automatically clear settings after logout”.
I find this really inconvenient when several users are using HA.
