Change value in yaml sensor code to a Input_text value
Hi everyone
Im not a coder, just edit code enough to get myself into trouble
I have this sensor defined in configuration.yaml
template:
  - sensor:
      - name: "Preço Electricidade"
        unit_of_measurement: "EUR/kWh"
        state: >
          {% set cv, ci, ev, ei, pv, pi, hv = bool(states("schedule.eda_cheias_verao")),
                                              bool(states("schedule.eda_cheias_inverno")),
                                              bool(states("schedule.eda_vazio_verao")),
                                              bool(states("schedule.eda_vazio_inverno")),
                                              bool(states("schedule.eda_ponta_verao")),
                                              bool(states("schedule.eda_ponta_inverno")),
                                              (5 < now().month < 11) %}
          {% if (cv and hv) or (ci and not hv) %}
            {{ (0.1736 * 1.16) | round(4) }}
          {% elif (ev and hv) or (ei and not hv) %}
            {{ (0.1072 * 1.16) | round(4) }}
          {% elif (pv and hv) or (pi and not hv) %}
            {{ (0.2416 * 1.16) | round(4) }}
          {% endif %}
what I want is to replace the number 0.1736 / 0.1072 / 0.2416 with the values from text input helpers (example: input_text.eda_preco_cheias)
I break the sensor every time i try this, anyone can help me with the right way to code it ?
I had tried (states(“input_text.eda_preco_cheias”)) … but broke it
Any help welcome
Is there a reason you are using a text helper rather than a number?
Try
int(states('input_text.eda_preco_cheias'))
e.g.
{{ (int(states('input_text.eda_preco_cheias')) * 1.16) | round(4) }}
This will only work if you are putting a number into the text helper, if it’s not a number it will return 0.
I changed to number, I then edited the code as follows:
  - sensor:
        state: >
            {{ (int(states('input_number.eda_preco_cheias')) * 1.16) | round(4) }}
            {{ (int(states('input_number.eda_preco_vazio')) * 1.16) | round(4) }}
            {{ (int(states('input_number.eda_preco_ponta')) * 1.16) | round(4) }}
          {% endif %}
and then on the helper I added the number
example
Screenshot 2024-10-01 at 14.16.24
But with that code, the sensor price comes back as 0
Screenshot 2024-10-01 at 14.17.13
is it because I am using decimals instead of a whole number ? i need to use decimals
I’ve re-read the Jinja documentation and realised you need to use float() rather than int().
This should work without any changes to the input_number:
{{ (float(states('input_number.eda_preco_cheias')) * 1.16) | round(4) }}
Thank you !!! … that does seem to be working. really appreciate
