Change value when number decreases
Hi there,
I am struggling with my automation: the climate entity should set the temperature in case it has been set a lower value compared to the previous one:
alias: Sync Wohnraum Thermostats
description: ""
  - platform: state
    entity_id:
      - climate.arbeitszimmer_2
    attribute: temperature
  - platform: state
    entity_id:
      - climate.badezimmer_2
condition:
  - condition: template
    value_template: "{{ trigger.to_state.state|float > trigger.from_state.state|float }}"
  - service: climate.set_temperature
      temperature: "{{trigger.to_state.attributes.temperature}}"
      entity_id: climate.wohnzimmer_2
    enabled: true
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
mode: queued
max: 2
What am I missing?
If you want to set the temperature to its previous value use:
trigger.from_state.attributes.temperature
Your condition is checking if the new value is higher than the previous value.
Change this:
To this:
temperature: "{{trigger.from_state.attributes.temperature}}"
At the moment you are setting the thermostat to the temperature it changed to. i.e. no change.
When what you want to set the temperature to is the the temperature it changed from.
EDIT: scooped by 123 again!
to > from means increasing, nor decreasing, maybe thats the reason?
Yeah there is that as well. Should be:
condition:
    value_template: "{{ trigger.to_state.state|float < trigger.from_state.state|float }}"
Also to avoid errors the triggers should be changed to:
  - platform: state
    entity_id:
    not_to:
      - unavailable
      - unknown
  - platform: state
    entity_id:
    not_to:
      - unavailable
      - unknown
This will still allow triggering on any change of the temperature attribute but will not trigger on changing to an unknown or unavailable value which will cause errors with the template condition.
