I have issues with coverage so I want to change to external USB connected wireless. To accomplish this I googled to find a supported device and was recommended the Alfa AC1200.
When I connect it I find the following in dmesg:
[ 2.372371] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8812, bcdDevice= 0.00
[ 2.372394] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.372409] usb 1-1.4: Product: 802.11n NIC
[ 2.372420] usb 1-1.4: Manufacturer: Realtek
[ 2.372432] usb 1-1.4: SerialNumber: 123456
But still I only get the default wireless device, no new one. I also tried changing in config.txt adding “dtoverlay=disable-wifi” and that disables the internal one but again no new wireless device.
All my devices for network (without the disable-wifi overlay):
~ $ ifconfig
docker0 Link encap:Ethernet HWaddr 02:42:E1:53:07:CD
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
inet6 addr: fe80::42:e1ff:fe53:7cd/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:26 errors:0 dropped:0 overruns:0 frame:0
TX packets:227 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2820 (2.7 KiB) TX bytes:31830 (31.0 KiB)
eth0 Link encap:Ethernet HWaddr DC:A6:32:61:D0:AF
inet addr:10.0.0.209 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::18e8:ab69:d97a:8529/64 Scope:Link
inet6 addr: fdf1:68ec:ca1:10:2bda:6a47:304b:8fb4/64 Scope:Global
inet6 addr: 2001:4645:cdda:0:d468:2583:b5c7:2e6a/64 Scope:Global
RX packets:11537 errors:0 dropped:0 overruns:0 frame:0
TX packets:7989 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:7470443 (7.1 MiB) TX bytes:2769480 (2.6 MiB)
hassio Link encap:Ethernet HWaddr 02:42:FA:75:61:41
inet addr:172.30.32.1 Bcast:172.30.33.255 Mask:255.255.254.0
inet6 addr: fe80::42:faff:fe75:6141/64 Scope:Link
RX packets:2909 errors:0 dropped:0 overruns:0 frame:0
TX packets:7380 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:760263 (742.4 KiB) TX bytes:5126291 (4.8 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:613 errors:0 dropped:0 overruns:0 frame:0
TX packets:613 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:43796 (42.7 KiB) TX bytes:43796 (42.7 KiB)
veth3b10d9f Link encap:Ethernet HWaddr E2:23:68:E6:7A:38
inet6 addr: fe80::e023:68ff:fee6:7a38/64 Scope:Link
RX packets:71 errors:0 dropped:0 overruns:0 frame:0
TX packets:3777 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:21982 (21.4 KiB) TX bytes:606872 (592.6 KiB)
veth3e56a15 Link encap:Ethernet HWaddr 8A:90:99:E0:93:CF
inet6 addr: fe80::8890:99ff:fee0:93cf/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:4424 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:690998 (674.8 KiB)
veth45a5674 Link encap:Ethernet HWaddr 62:54:B7:45:C2:8C
inet6 addr: fe80::6054:b7ff:fe45:c28c/64 Scope:Link
RX packets:229 errors:0 dropped:0 overruns:0 frame:0
TX packets:1785 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:21342 (20.8 KiB) TX bytes:781391 (763.0 KiB)
veth48564ae Link encap:Ethernet HWaddr 16:CB:FF:21:78:75
inet6 addr: fe80::14cb:ffff:fe21:7875/64 Scope:Link
TX packets:4428 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:691236 (675.0 KiB)
veth691a45d Link encap:Ethernet HWaddr 4E:37:EF:99:19:54
inet6 addr: fe80::4c37:efff:fe99:1954/64 Scope:Link
RX packets:45 errors:0 dropped:0 overruns:0 frame:0
TX packets:3674 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4725 (4.6 KiB) TX bytes:601748 (587.6 KiB)
veth7917862 Link encap:Ethernet HWaddr 6E:0F:02:01:F3:77
inet6 addr: fe80::6c0f:2ff:fe01:f377/64 Scope:Link
RX packets:248 errors:0 dropped:0 overruns:0 frame:0
TX packets:2004 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:34842 (34.0 KiB) TX bytes:336865 (328.9 KiB)
veth916ea74 Link encap:Ethernet HWaddr CE:B4:A7:5D:02:6C
inet6 addr: fe80::ccb4:a7ff:fe5d:26c/64 Scope:Link
RX packets:742 errors:0 dropped:0 overruns:0 frame:0
TX packets:4852 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:90119 (88.0 KiB) TX bytes:702373 (685.9 KiB)
vetha50e147 Link encap:Ethernet HWaddr D2:2A:99:F5:30:BA
inet6 addr: fe80::d02a:99ff:fef5:30ba/64 Scope:Link
RX packets:315 errors:0 dropped:0 overruns:0 frame:0
TX packets:4570 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:33578 (32.7 KiB) TX bytes:707652 (691.0 KiB)
vethba32ecb Link encap:Ethernet HWaddr 12:C3:4A:58:A1:AA
inet6 addr: fe80::10c3:4aff:fe58:a1aa/64 Scope:Link
RX packets:1278 errors:0 dropped:0 overruns:0 frame:0
TX packets:4965 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:164857 (160.9 KiB) TX bytes:4085305 (3.8 MiB)
vethd5c0b89 Link encap:Ethernet HWaddr 2A:C6:27:B5:10:37
inet6 addr: fe80::28c6:27ff:feb5:1037/64 Scope:Link
TX packets:1661 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:244983 (239.2 KiB)
vethe23b253 Link encap:Ethernet HWaddr 6A:B3:03:3F:21:AC
inet6 addr: fe80::68b3:3ff:fe3f:21ac/64 Scope:Link
TX packets:259 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3184 (3.1 KiB) TX bytes:37535 (36.6 KiB)
vethe619851 Link encap:Ethernet HWaddr 3A:85:DE:D5:67:39
inet6 addr: fe80::3885:deff:fed5:6739/64 Scope:Link
RX packets:800 errors:0 dropped:0 overruns:0 frame:0
TX packets:5329 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:582786 (569.1 KiB) TX bytes:1061095 (1.0 MiB)
wlan0 Link encap:Ethernet HWaddr DC:A6:32:61:D0:B0
inet addr:10.0.0.10 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::ae78:a0f8:6240:9eb2/64 Scope:Link
inet6 addr: 2001:4645:cdda:0:3d2b:20d9:75e5:5b6f/64 Scope:Global
inet6 addr: fdf1:68ec:ca1:10:fbdc:a4cf:a384:bb50/64 Scope:Global
RX packets:5160 errors:0 dropped:0 overruns:0 frame:0
TX packets:325 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:579417 (565.8 KiB) TX bytes:49209 (48.0 KiB)
I was expecting the new one to show as wlan1 for example… My hardware is Raspberry Pi4, 4GB ram.
Any tips?
