Change Z-Wave Dimmer to standard switch (on/off)
Recently switched from SmartThings to HA. I have all my devices on HA right now (ZigBee/Z-Wave/IP). I am having some issues with my in-wall Z-Wave dimmer switches. When controlled at the switch itself, it doesn’t report to HA. When I try to control from HA the device shows it’s turning on and then turns off then reports on. I’ve changed the config.yaml to allow for refresh and polling but they are still not updating. Is there any way to change zw_config.xml file to change it to a switch rather than a dimmer?
I have some z-wave dimmer plugs that work just fine. They report everything perfectly fine. The only issue right now are the Z-Wave dimmer in-wall switches.
Using pi4 with Nortek HUSBZB-1 ZigBee/Z-Wave USB Stick
Home Assistant 0.117.5
Evolve LRM-AS
Leviton VRI06-1LZ
