I was running a Conbee II stick with Deconz on channel 25.
I moved to Skyconnect with ZHA end ran in a ton of instabillity issues. I found out that I’m running on channel 15 now. That is in my appartment not the most optimal channel due to an overcrowded WiFi spectrum.
So I was trying to change the channel of the skyconnect. As far as I know that can be done by adding some lines in configuration.yaml and the ‘migrate radio’ button.
But absolutely nothing happens when I click on that button. Is there something I’m missing?
