Migrated my installation of HomeAssistant from my old x86 based Dell T420 with Proxmox hosting HomeAssistant 6+ weeks ago, and also replaced my aging HUSBZB-1 with a Conbee3 and Zooz 800 LR. Originally used a uSD card on my 4GB Pi4, as I didn’t have an M.2 adapter for the Pi, or an M.2 for it. Got both of those in, in the form of the 52pi DeskPi Lite NAS case. Nice case, could use some “ease of assembly” improvements, but nice case. Flashed HomeAssistant to the M.2 using the Raspberry Pi Imager, after a couple tries, as the adapter the case included was for a SATA M.2, not an NVMe (this has been fun…)
On the uSD, moving from the HUSBZB-1 to the Conbee2, then 3 (Bought the wrong one, and took a couple days to realize/swap), no issue, after like an hour for the network to reconnect.
But when I put the M.2 in, suddenly Zigbee was dead. I got a TZDATA error (unfortunantly, I forgot the full error, but I remember it ended in “167”, and the error attached at the bottom, I found after trying to revert to a couple different backups, and swapping back and forth between the Conbee and the HUSBZB-1, as I still have it.)
I tried re-installing ZHA, and all it’s gotten me is my Zigbee network of 26 clients have ALL lost their names/locations, but Zigbee has been down for at least 2 days now, and neither coordinator is seeming to even talk. ZHA in HomeAssistant shows the “last seen” as some amount of time in the past (the other night it was ~3 hours before, now it’s showing an hour ago.) the coordinator is showing the firmware, the MAC address. Nwk is 0x0000, LQI is 255, and RSSI is unknown. (I only recognize RSSI off the top of my head, as that is signal strength, and should have a dB value.)
I even tried pairing one of the zigbee devices in my house last night manually, to see if it was just having issues “restoring” the old network, but it didn’t see the device when the device tried to pair.
Home assistant is showing no updates needed, but 41 automations are dead, as the zigbee devices involved are all “missing”.
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
First occurred: 10:10:52 PM (2 occurrences)
Last logged: 10:11:00 PM
Error handling request
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 285, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 414, in _async_configure
result = await self._async_handle_step(
flow, cur_step["step_id"], user_input
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 517, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 469, in async_step_choose_automatic_backup
return await self.async_step_maybe_confirm_ezsp_restore()
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 488, in async_step_maybe_confirm_ezsp_restore
return await self._async_create_radio_entry()
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 803, in _async_create_radio_entry
await self.hass.config_entries.async_setup(self.config_entry.entry_id)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2031, in async_setup
raise OperationNotAllowed(
...<3 lines>...
homeassistant.config_entries.OperationNotAllowed: The config entry 'Conbee3' (zha) with entry_id '0436727d11ed6bafce453f9cfc365a15' cannot be set up because it is in state ConfigEntryState.SETUP_RETRY, but needs to be in the ConfigEntryState.NOT_LOADED state
