Changes in bluetooth discovery?
long story made short: i just found out that in a random moment between some months ago and today the bluetooth discovery of LD2450_BLE devices broke, so i’m wondering if there is a way to know if/what was changed.
Basically, it keeps saying that no device is found, but i checked at bluetooth stack level if they are seen (and they are), so it seems just devices are no longer identified based on the content of manifest.json amd also in the config_flow file it seems “something happens”, but not as intended.
There is a very similar integration (for LD2410_BLE) that is declared as “official” for home assistant and seems to have the same issue, so something seems to have changed in general. Sadly i’ve not been using the LD2450 module for a while so i have totally no idea of when it happened and i’m scared about having to walk backward through every single version and subversion, do you know any different way to find modifications that could impact bluetooth devices discovery?
thanks
