I have a problem with changes on my Integrations.
When removing one or more Integrations and rebooting the pi the integration is available again. This seems like a general problem as I also need to pre-authorized the tuya integration and this happens after each reboot of the system.
I have already re-installed the whole system from scratch and restored from an backup but the behavior describes still exists.
Do you guys have any idea what is going wrong here and how to solve that?
Sure I am running home assistant on an RPI5 (previously 4 but same behavior there) but can’t tell exactly when this happened the first time.
Core2024.10.2
Supervisor2024.10.2
Operating System13.2.rc1
Frontend20241002.3
I am running quite a while on Beta and this is not related to the latest beta release, it happend also already earlier.
Also already checked the homeassistant.log as well as the homeassistant.log.1 but was not able to find anything that could be related to this or explains the behavior.
Just removed the logs from the gui, deleted some more integrations and found that:
Logger: homeassistant.helpers.storage
Quelle: helpers/storage.py:542
Erstmals aufgetreten: 16:00:11 (3 Vorkommnisse)
Zuletzt protokolliert: 16:00:18
Error writing config for core.config_entries: Failed to serialize to JSON: /config/.storage/core.config_entries. Bad data at
and
Logger: homeassistant.helpers.json
Quelle: helpers/json.py:220
Alright short update on this, I was able to fix it, anyhow the Meross integration made about 400 inherited arrays in the parameter “mqtt_domain” which led to an error in the serialization of the json.
Topic can be closed, thanks for your support on this guys!
I see that you fixed it with the Meross issue, but what did you actually do to fix it? I’m in the same position now and I also have the Meross integration.
Hi all, exact same issue with tuya and other integration (I have meross too and also all those brackets…) …just updated… reboot and… ISSUE SOLVED!! you made my day (at least with HA) my friend!! solved an old issues I was having since MONTHS!! thanks @sharkyy112
Just a word of warning for those of you who fixed the problem by removing the excess [ ] from the config_entries / meross entry, I have noticed that for some reason a new set of [ ] gets added on every reboot of Home Assistant.
I’ve added details of this to an already open issue on github:
Probably worth checking to see if you are getting the same build up of brackets in your config_entries file, as I think when it gets to a certain number it will cause the issues with other integrations again.
