I didn’t see any notes about it in the release notes, but upgrading to the 2023.5.0 release has removed two sensors from Airthings that were literally there yesterday. These two sensors should be reading “Low” or “Very Low”:
I have four of these that reported this value yesterday, and I have four that no longer do. I can create them with template sensors that evaluate the actual pCi/L readings but I shouldn’t have to.
2023-05-20 22:26:41.154 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 581, in state
numerical_value = float(value) # type:ignore[arg-type]
ValueError: could not convert string to float: 'moderate'
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 204, in _handle_refresh_interval
await self._async_refresh(log_failures=True, scheduled=True)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 349, in _async_refresh
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 146, in async_update_listeners
update_callback()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 406, in _handle_coordinator_update
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 585, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 649, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 591, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 583, in state
raise ValueError(
ValueError: Sensor sensor.airthings_wave_135154_radon_1_day_level has device class None, state class measurement unit None and suggested precision None thus indicating it has a numeric value; however, it has the non-numeric value: moderate (<class 'str'>)
