Hi all!
Changes I make to manifest.json
are being ignored when I (re)start the HA devcontainer.
My initial manifest.json
looked like this:
"domain": "my-integration-domain",
"name": "My Integration",
"codeowners": ["@GithubUser"],
"config_flow": true,
"dependencies": ["mqtt"],
"documentation": "https://www.home-assistant.io/integrations/my-integration",
"integration_type": "hub",
"iot_class": "local_push",
"mqtt": [ "app/config/#" ],
"requirements": ["mymqttapi @ ../mymqttapi/"],
"single_config_entry": false
I want to change the mqtt
array to this:
"mqtt": [
"app/config",
"app/+/state"
But in the async_step_mqtt
step of the config flow, the only topic that comes in is app/config/#
(note the hash). I monitor discovery_info.subscribed_topic
to check this.
Things I’ve tried so far:
- Setting the mqtt property to an empty array. Step is still executed with first topic that was configured (the one with the hash)!
- Rebuilding the devcontainer.
- Googled
- Checked HA developers documentation
Is there any way to force a reload of the manifest.json file?
If it matters, I’m running the devcontainer through WSL.
Thx!
