Hi all,
I’m wanting to stop my home battery from discharging while my air source heat pump is in operation during the day (it drains it so quickly that it becomes almost worthless). I don’t want to turn the whole system off as this stops any solar that is being produced from being used as well as the battery.
What I am hoping to achieve is to change:
Select. solax_discharger_end_time_1
From whatever time it is set to to the nearest 15 minute window (it can only be changed to :00 :15, :30 or :45 past the hour)
I’d also want to change
Select. solax_discharger_start_time_2
The same conditions apply, but I’d want to set that to a time a few hours in advance.
I’d also want the battery to kick back in when the heating reaches the target temperature; so essentially reverse the above process.
How would I go about this? I’m assuming I’ll need scripting and I don’t know where to start on that one.
