Hi all,
I’m trying to use an if statement in a scipt to change the media player based on what is currently palying.
The media player (media_player.sonos_1) is passed on to the script as a variable via an automation that is triggering the script. If the current source of media_player.sonos_1 is “AirPlay” I want to switch to media_player.sonos_2 so that media_player.sonos_1 is not interrupted.
This is my code:
#### Sonos Play File
sonos_play_file:
alias: "Sonos Play File Script"
mode: queued
sequence:
- if:
- condition: state
entity_id: media_player.sonos_1
attribute: source
state: "AirPlay"
then:
- variables:
sonos_entity: media_player.sonos_2
The if statement works correct based on the source of media_player.sonos_1. However, the variable is not changed.
If I just start with changing the variable without the if startement:
sonos_play_file:
mode: queued
sequence:
- variables:
the variable ist changed. Is there anything wrong with my code? Do I need to use another syntax to change variables within the if statement?
Thanks in advance!
This is likely a scope issue, but you haven’t shown where you are using the sonos_entity
variable, so it’s hard to say for sure.
The way you have shown it, the variable will have the value media_player.sonos_2
only within the then
. If you need it to have a wider scope you will need to use templates:
sonos_play_file:
mode: queued
variables:
sonos_entity: "{{ 'media_player.sonos_2' if is_state_attr('media_player.sonos_1', 'source', 'AirPlay') else 'media_player.sonos_1' }}"
sequence:
EDIT: Added missing attribute reference
Perfect. Thanks a lot. I had to change if is_state to if is_state_attr and add the attribute name, but than it solved my problem already.
sonos_play_file:
mode: queued
variables:
sonos_entity: "{{ 'media_player.sonos_2' is_state_attr('media_player.sonos_1', 'source', 'AirPlay') else 'media_player.sonos_1' }}"
sequence:
One more question: sonos_entity might contain a string with more than one sonos entities. Is it possible to leave it as it was if the source of media_player.sonos_1 is not AirPlay?
variables:
sonos_entity: |
else sonos_entity }}
sequence:
Though, you may want to add a default or further conditions to the template is there’s a chance that sonos_entity
might not be provided and sonos_1
’s source isn’t AirPlay…
