Changing brightness of light group up/down not working
I am trying to change the brightness of my light group using a Philips Hue Dimmer. I can get it working if I automate each light on it’s own but wanted to streamline a little.
The lights are turning on/off all the same time but I cannot get the dimmer to work. I’ve tried both using a value % and a set value but it doesn’t change the brightness.
alias: "Entrance Hue Remote "
description: Blueprint
use_blueprint:
  path: dustins/zha-philips-hue-v2-smart-dimmer-switch-and-remote-rwl022.yaml
  input:
    zha_device: 5d59bc73d754db41ca93d3d6394bbd8a
    Power_Press:
      - service: light.toggle
        data: {}
          entity_id: light.entrance_lights_local
    Up_Press:
      - service: light.turn_on
          brightness_step: 25
    Down_HoldPress:
          brightness_step: -25
    Up_HoldPress:
          brightness_step: 25
    Down_Press:
    Power_Press2x:
      - type: toggle
        device_id: e2ee9ee1daf9284e286e92b2af26b22c
        entity_id: light.outside_light_local
        domain: light
    Hue_Press: []
I should add that I am trying to control Tuya wifi bulbs with LocalTuya integration so maybe I had sone something wrong in the initial setup of the devices?
