So i’m trying to change a parameter on my AEOTEC Recessed Door Sensor and it seemed pretty straight forward. I want to change configuration option 121 to a value of 16.
Wow that actually worked! The key to using OZWCP was pressing the “Action” button on the sensor so i could actually see the config options. That’s what was causing me to go from OZWCP to straight command line but this is way better now that i know what i was doing wrong.
@kirby - can you shed any light on this? I just got my ZW089-A in tonight - and this is EXACTLY the issue I’m having. I’ve tried keeping the device awake while setting the setting from basic set to binary report and all I get in the console is the “post: key=14-CONFIGURATION-config-list-1-121 data=Sensor Binary Report size=20
2017-03-22 19:54:17.410 Warning, Invalid Index Set on ValueList.” warning.
