Changing connecting from LAN to WiFi (HA2025.1.0 RPi4)
Good evening.
My home renovation starts the day after tomorrow. I have to move my HA equipment to another place for two weeks without the possibility of connecting a cable. I have everything on RPi4, so there is WiFi. And here’s a surprise… I want to turn on WiFi today and move the equipment and after click “Scan for access points " … here’s a window with info " Failed to scan for accesspoints. Scanning not allowed while unavailable”:
I have no idea what now…
After pressing “reset configuration” nothing changes.
System Information
version core-2025.1.0
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.13.1
os_name Linux
os_version 6.6.62-haos-raspi
arch aarch64
timezone Europe/Warsaw
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
HACS Data ok
GitHub API Calls Remaining 5000
Installed Version 2.0.2
Stage running
Available Repositories 1494
Downloaded Repositories 39
AccuWeather
can_reach_server ok
remaining_requests 10
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 14.1
update_channel stable
supervisor_version supervisor-2024.12.3
agent_version 1.6.0
docker_version 27.2.0
disk_total 234.0 GB
disk_used 18.5 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board rpi4-64
supervisor_api ok
version_api ok
installed_addons File editor (5.8.0), Mosquitto broker (6.4.1), Zigbee2MQTT (2.0.0-1), Advanced SSH & Web Terminal (20.0.0), FTP (5.1.1), ESPHome Device Builder (2024.12.2), HassOS I2C Configurator (0.14)
Dashboards
dashboards 3
resources 24
views 14
mode storage
Recorder
oldest_recorder_run 25 grudnia 2024 20:25
current_recorder_run 5 stycznia 2025 18:28
estimated_db_size 830.36 MiB
database_engine sqlite
database_version 3.47.1
Hello elpaul,
I do not suggest doing that, it is often the root of other problems, but that said…
If When you come back for help here, please let the person helping know your server is on WIFI.
