I have a command line cover configured. It controlls a garage door.
Now i want to change the icon of this cover.
The configuration of a ‘Template Cover’ has tho option to define a ‘icon_template’. The command line cover has no option like this as i see.
Whats possible is to define an icon in the customize.yaml. This is static and not depending on the state of the door.
I tried different configuration variants i found in the forum but it was not working or i got errors whith checking the config file.
M1ke
2
Yes, this is by default only possible for things with ‘platform: template’
You have to install the following to get the ability to change everything: https://github.com/Mariusthvdb/custom-ui
wmaker
(Tommy Long)
3
You may already know this, but an just in case, an alternative would be to add to your customize.yaml device the following:
cover.your_garage_door_name:
device_class: garage
Thank you, friend. It work for my group cover:
covers.yaml
- platform: group
name: "Sons room blinds"
entities:
- cover.sons_blind1
- cover.sons_blind2
customize.yaml
cover.sons_room_blinds:
device_class: blind
at last i have blind icon instead window
