Changing device tracker picture size in lovelace glance card
OK, just started with hass.io on an RPi3 and am using lovelace as well so be gentle.
I have three devices that show their state as away or home just fine. In the known_devices.yaml file I was also able to add a custom picture that shows, but is smaller than I’d like. (the pictures are larger than they are displayed) The lovelace entry is,
type: entity-filter
        entities:
          - device_tracker.mike5s
          - device_tracker.jensnote3
          - device_tracker.kilbynote8
        state_filter:
          - home
        card:
          type: glance
          title: Who is Home?
          show_state: false
          show_name: false
Is there a way to set the size of the displayed png as well?
GreyBeard, did you find a solution? I’m running into the same issue. But I also couldn’t get the images to work from the known_devices.yaml, had to use the customize.yaml instead.
